GaryPClearwater
- Mar 10, 2014
- 1
I can see water in the front bilge through the drain hole in the compartment under the step into cabin. I've got a switch labeled "Fwd Bilge Pump" that lights up but doesn't do anything.
Boat is in a lift, and I pulled if forward to get it "nose up" as much as I could (I don't have a trailer), but water doesn't drain from the front to the rear bilge compartment.
Are fore and aft bilge connected?
Looks like there is a channel at the fore end of engine compartment that would connect to bilge under cabin.
Any help greatly appreciated!
