Re: Capacity Plate Information
There seems to be some uncertainty about capacity plates. When a manufacturer decides to build a type of hull, it gets together with a Coast Guard or a BIA representative and they go over blueprints to see that the hull conforms to regs. Once the hull is built, the Coast guard or BIA tests it to see that it will carry the capacity that the Coast Guard formula implies it will. Then the hull is certified and the manufacturer can put on a capacity plate.
It is not illegal to replace a capacity plate as long as the same numbers as the original are used. Here is one I made.
You have a computer and it most likely came with graphics. Make your own plate, print it, and laminate it. But put some effort into it to make it look decent--if not professional, at least not amateurish. Then attach it to the hull. I think I used the business card or address program to make mine as I did not need or want to put on graphics.
Unless your hull is very small, 70 HP does not seem excessive so if you can not get actual numbers, make a plate for 75 horsepower. No warden or conservation officer will question it.
