jkimball
- May 14, 2013
- 220
I have a '99 Four Winns Horizon 170, with a 115 Johnson OB.
on the back swim platform I have a folding swim ladder on the Starboard side.
while underway the base of the ladder seems to drag a little in the water and throws water back in the boat.
I've tried trimming up & down with little to no effect, the only caveat is when I have the bow loaded down with people, it seems to kind of pull it out of the water a little, or maybe I don't notice it as much.
The prop I have on is a 17p OMC SST, for tubing, skiing and when I'm loaded down. I also have a 19p SS Viper.
I don't know if my problem is that I need more of a stern lifting prop, or if there is something else that could be causing this so I didn't post in the prop section...
Has anyone experienced this and can give some insight?
