Ok I have replaced the horn on my 2003 Searay every year now for 4 years. It came from Searay with a dual horn oval ~6" x 3". It sounds like a buzzer, you know the ones. Well doing winter maintenance and decided to ask a question. What is the BEST horn to replace the original horn. I want a real sounding horn. Not afraid to do a little modifying of the hole if needed. The original horn is a Searay #1413475. I believe the Aqua Signal Series 84201-1 fits and the Aqua Signal 84400-1 would fit with a little cutting of the area between the existing holes.
Look forward to any advice here !!
Thanks,
Mike
Thanks,
Mike
