Martysmarty
- Nov 23, 2013
- 1
Hello. I am new to this forum and I need some help with this boat project that is becoming a time machine, or should I say a time eating machine. My 1975 'ish Livingston catamaran has been sitting in my yard for 10 years and I finally built a shop and started to restore her. I started by scraping and sanding the hull(s) of anti fouling paint, marine paint, gelcoat, bondo and some sort of epoxy filler. I reglassed any thin spots and primed and used a marine enamel, wet sanding between brushing and rolling the paint. I finally finished and turned the boat right side up to begin the topside. I removed the weak thin floor(s) and also cut out the back seat cavities and removed all the waterlogged flotation. Now I am ready to add floatation foam,fiberglass in storage boxes, seats, reinforce and strengthen the transom and make this boat into a useful boat for many years to come. I need help with the next few steps, mostly the flotation and drainage. If you have some experience with flotation especially with these older Livingston's I would really appreciate some help. I have some ideas but I want to make sure I know what I am doing. I want to level off the floor with foam, running plastic piping in the keel channels to have a very sturdy floor. Thanks
