Re: how fast would a bigger motor make it go!
The general rule of thumb is that it takes four times the horsepower to double the speed. However, there are a lot of variables. If you roughly double your horsepower to the 200, I suspect that yes, you would get in the mid 50s
Actually, you are on the right track. :joyous:
The Force(Drag) is proportional the Square of the Velocity.
Power(hp) is the Force time the Velocity.
Twice the Velocity pushing 4 times the Force requires 8 times the Power.
The Power is proportional to the
Cube of the Velocity.
There are a lot of other variables that make and accurate answer problematic.
But, assuming laboratory conditions and a simplified textbook answer....
If 88hp produces 34mph.
200hp is 2.27 time the power.
The cube root of 2.27 is 1.31.
1.31 time 34mph yields 44mph with 200hp.
The extra 112hp will theoretically buy you 10mph. Your results will vary.
This all assumes that the larger hp engine and added fuel does NOT add any extra weight.
55mph /34mph = 1.62, Cubed = 4.23, * 88hp = 373hp to theoretically go 55mph.
Realistically, well over 400hp may be required.
This is a classic case of diminishing returns. Sorry! :blue:
