My Crownline 270 CR is equipped with a factory installed hot water heater which is a Seaward S650 model. The problem is that it only works on AC current when the boat is plugged to shore power. Most of my boating time is done on anchor so I have no AC current and so I have no hot water either. Is there a way to connect to water heater to the engine coolant lines ? I know some boats come like this from the factory.
I also can't find a way to disconnect the existing factory lines / pipes which feed the water heater from the fresh water tank. The plumbing is Whale Quick Connect .
The boat is powered by a 350Mag Mercruiser engine .
*** Edit :Seaward Water Heater Model is S650 not F650 sorry !
