Re: add on trim gauge
Piece of cake. They sell trim gauges in the store at iboats, as well as many other online boat stores. Just be sure you get one for OMC outboards (Johnson/Evinrude). ALSO, you'll need to make sure your engine has a trim sender. It's a black disk maybe an inch and a half in diameter or thereabouts with an arm coming out of it, and it'll have wires coming out of it. I'm pretty sure on your engine it'll mount on the inside of the port side midsection near the top (you can go to shop2.evinrude.com and find your engine model, it'll be shown in the "midsection" diagragrm). AND sometimes the senders go bad, with an ohmmeter make sure that as you move the arm from one end of its travel to the other that the resistance varies smoothly. And if you need help with figuring out the wiring just yell.
