Just me again
- Dec 12, 2013
- 7
I am replacing my fuel pickup. It's in a 160gal tank below the deck. The old PU has been removed, and has a heavy brass screen filter assembly at the end of the flexible tube.
In my attempt to remove the filter from the tubing, I had to revert to trashing the crimp collar that secures the flex hose to the assembly.
Any suggestions on replacing this collar? The screen assy is a tight fit into the tank so anything must have an OD of less than .500 and an ID to fit over the tube more than .440. I don't want the next guy pulling on it only to lose it at the bottom on the tank. I have not seen a total filter assembly replacement to buy either.
