Hi and thanks in advance for any advice. I'm looking to purchase a small aluminum boat to use primarily for fishing. This boat will primarily be used in a 1200 acre lake (max lake depth about 70' if it matters). I would like to have one we could take over to the puget sound or the columbia river if ever desired, but it's not my primary emphasis. We are a family of 4 so want one that we could all be out on at times, but oftentimes I suspect it could be just me out alone...and sometimes with one of my kids.
The boat will be moored in the water through the summer. I want to keep maintenance and problems to a minimum and am trying to keep my costs down by purchasing a used boat ($1000 - $1750 range). I figure by keeping my costs down if we don't use it or if we decide we want something a bit different over time I'm not out a lot of $.
I was thinking aluminum because I like the idea of being able to power it when trolling with an electric trolling motor.
One of my specific questions is whether a 15" transom is fine, or if I should look for a 20" transom? Also, I've seen some people build up the 15" transom to run a long shaft motor, any concerns with that?
I also see various beam widths. Is there a minimum beam width that you'd recommend for stability?
I see deep V, semi-V, modified V and square flat bottoms. I think I want to stay away from a flat bottom boat. Are advantages/disadvantages to the others that would matter to me?
Is the age of the boat a concern? I see lots of them going back into the 70s that still appear to be in good condition.
From reading through the forums and doing some initial research I think 14' is about right....let me know if that seems off. Lots of great deals out there on 12' but I am thinking those might be too small.
Any particular brands that are either recommended, or ones to stay away from?
Thanks again everyone for taking the time to read this and respond with your thoughts.
