minuteman62-64
- Apr 12, 2011
- 1,350
Getting ready to do some work in my boat which will include using blind rivets. Bought the HF air tool with 1/4" capacity. Based on reviews they either are crap right out of the box or give good to great service. So, gave it a test to see which one I had and so I can return it immediately if a problem.
Tested it at 100 psi on a 1/4" blind rivet. I bought a bunch of these years ago and have destroyed two supposed "heavy duty" manual tools trying to set one.
Drilled a 1/4" hole in some 1/8" aluminum. Stuck the mandrel in the gun, inserted the rivet in the hole, pulled the trigger and - wham! Fully set with one trigger pull (see attached photos).
I don't know if I'll use the 1/4" blind rivets in my project, but, it's nice to know I can pull them if I do.
Only issue with the gun so far: The bottom is supposed to unscrew to allow checking the oil reservoir. Tried the enclosed spanner and up to a 24" pipe wrench - no way that sucker is coming off. I guess I'll end up using the gun till performance drops off due to insufficient oil in the reservoir, then buy a new one. Oh well. That's HF
