2003 Sea Ray 200 Bow Rider - MarineMax - United by Water
It's near my house so I pass it daily. $13,770 advertised. Sea Ray (Select hull) specs reflect 21ft, heavier and wider than what I have so I'll have the improved ride, more power, ideal seating layout. It looks well cared for, hours are low and I'm feeling it is lift kept due to no trailer and the outdrive being mint (no corrosion).
Turn off's:
-Nearly 11 years old...
-Carb engine...
-I'd need to buy a trailer at around $2,500 (current one isn't HD enough to adapt).
Should my con's be enough to keep looking else ware?
Turn off's:
-Carb engine...
