boater1234
Master Chief Petty Officer
- Jan 6, 2010
- 869
I have a little issue i hope i can get some help on.I was checking the back of my jon boat when i noticed a small hole right at or a bit above the waterline on the transom.If i had to guess the hole will be in the water less then half the time.It's about the size of a #8 screw head,not to big.This is what i was going to do to seal it.I was going to fill the tiny hole and around it a bit with fast cure 5200 and then just put a SS number 8 or 10 screw in it like an extra rivet.A quick permanent fix i think????????Is this the right way to do it?I can't see how it will ever leak doing it that way but i would like to know if that is the right or wrong way to do it????
Now i only plan on keeping this boat for prob a few yrs at the very most,maybe less.
If someone has a better quick idea please let me know,thanks.
