TH Automatic Aerator Control - Wiring Diagram???
teeford
I have a TH Marine automatic aerator controller on which I had to replace the SPDT rocker switch. Unfortunately, I unplugged all the wires from the unit when I removed it. I need a wiring diagram for this controller, or at least a photo of the back side of the unit as it comes wired from the factory.
teeford
Re: TH Automatic Aerator Control - Wiring Diagram???
Thanks for the diagram, but the TH controller has only three contacts on the timer, plus the three contacts on the rocker switch. One of the contacts on the timer is ground, leaving only two positive contacts. Problem is in finding out where these two positive contacts connect. Thanks.
