Dave-R
- Mar 18, 2008
- 441
The speedometer on my 350Mercruiser magnum did not work when I first bought the boat.After checking it out, I found it was cut under the drive. So I used a splice kit to repair it. I then blew from the gauge out to the drive, where I had it disconnected. Also blew backward thru the drive unit, and flows seemed good. Still did not fix the problem.
I ordered a new speedometer, but I still wonder if the splice was okay? Anyone have a similar problem? Thanks Dave R.
