captcouillon
- Apr 2, 2013
- 3
[Solved] Screwed in from the back.... access is PITA but doable.
Need to remove cockpit dash switch panel on a '91 310 Express cruiser. Several switches, breakers, etc need maint and/or replacement and so far, the only access I have been able to find is via the small port and stb "dash doors". Inadequate to work with a tight wiring harness. No fastners on exterior of panels. Anyone out there know how these panels are held in place, and or procedure to remove for service? Items in question are marked E-4P and E-4S in diagram below...
Thanks in advance
Cap' Couillon
Thanks in advance
Cap' Couillon
