marktwainsonic
- Jul 16, 2010
- 101
I have an '89 Sea Ray 4.3 Mercruiser (18 foot). The ski locker is holding water. After wet-vaccing the drain "well" and running a short stick and then a long coat hanger through the drain it still won't drain the water (the water is over the drain hole).
I did some research online (including here on iboats) that said vacuum it out or stick a screwdriver/coat hanger through the drain line . Any other ideas?
The coat hanger went in the full length of the wire and was not blocked by any solid obstruction.
Thank you in advance for any ideas.
