Re: volvo penta 275 wont unlock
Yes it has a eletro-mechanical tilt,,, When it's all the way down and locked the push rod from the tilt mechanism pushes on a plunger, which pushes on a link, which releases the arm so it can unlock and raise. If your tilt motor is weak, or you need to adjust the tension spring in the tilt unit, or if your push rod is bent which happens often, that may be the issue... Trust me they bend easily... use tilt unlocked and up at idle only. There is no "trim" on this while running.. If the drive jumps up and comes down the shaft will bend and they are not cheap...yes get a manual
