My steering is locked up on an old boat that sat for 10 years
I have an evinrude XP150
I have a twin cable teleflex rack system
If it matters I have a tilt able steering wheel
The motor rotates freely with the steering disconnected
I freed up both rods at the motor(they will move freely now by hand when disconnected)
Steering wheel will only turn 1/4 turn and the forward cable only moves an inch
The cable through the tilt tube doesn't move
Steering wheel is the same even with the cable ends disconnected.
I can rotate the front cable by putting a screwdriver in the bolt hole end about a 1/2 turn each direction and its springy
The cable through the tilt tube rotates freely clockwise forever, counterclockwise it will stop after awhile
Does this mean one of the teleflex cables are broken?
If so which one?
Is there any way to lubricate or use penetrating oil on the helm rack or pinion gear?
Thanks for your help
I have never worked on any of this before
If so which one?
