michaud500
- Sep 3, 2011
- 91
I need help with mounting a ladder to a 1964 Mirror Craft Ski n Troll. It is a aluminum hull with no leaks! I need to drill holes into the hull to mount the ladder. The question is how do I seal the holes properly and mount the ladder? I think I am being a little gun shy... I am going to make it so I can remove the ladder when it is not in use. I will use pins with the brackets permanently mounted to the boat. Thanks for the help!
