Re: Stinky water in Ski Cuddy
That all makes sense. I am new to boating so still learning. So when it goes forward is it a skinny pvc tube that takes it to the ski caddy or is it open under the gas tank and such to get to the caddy?
There is a short piece of tubing passing through each bulkhead. (Limber Holes)
The area under the Fuel Tank is open and needs to drain as much as any other compartment.
Pass a 3-4 foot dowel through it to make sure it is a clear passage.
If you are starting with a lot of stinky water, the Garboard Plug should always be be out when on land, if not already, remove it.
Crank the Bow all the way up.
Take a garden hose into the boat and Power Flush the Ski Locker, The Limber Tubes, and the Bilge area under the engine.
Some Dish-washing Soap and a little bleach is justified.
Small pieces of debris are the #1 reason bilge pumps get clogged and fail.
Flush everything you can, out the Garboard Drain.
While you are at it, fill the bilge with water to make sure the Bilge Pump is actually working, don't be surprised at the amount of water it takes before the Pump actually come ON. It is a Lot!
When finished get it all dry, COMPLETELY DRY!
P.S. I think the word you are looking for is CUDDY, not Cubby or Caddy.
