I am working on a boat trying to get it running
Hasn't been run in awhile and I want to try to get it running to make sure it is worth putting work and money into it. I am totally new to this and been looking through this site.
I have got the motor to turn over and run for a few seconds
How does the throttle work?
Can I move it without putting it in gear.
If I can't is it ok to move it with water hooked up.
Can I spray starting fluid in the black plastic thing covering the carbs
Thanks for any help
I don't want to screw anything up trying to start it
It is a 150 evinrude on a 18 ft glass bass tracker
I hooked it to a small tank and it has a mix tank hooked to the motor for oil
Thanks for any help
