Re: Composite or marine grade ply wood?
Hi Ajax,
There are a couple of key differences between marine grade and 'ordinary' ply wood. First, marine grade plywood has more plys of higher quality wood, than 'regular' construction plywood. This makes it both stronger and more stable than 'regular' plywood. Marine ply is suppposed to have fewer or no voids in it, making it structurally more sound. Second, marine plywood is glued together with waterproof glues, so it will stand up much better than when it wet. Exterior grade 'regular' plywood will also use waterproof glue however.
Key thing to know - avoid pressure treated plywood, as although it will stand up very well against water, it contains chemicals that can corrode aluminum and other materials.
There is nothing wrong with using exterior grade plywood. A number of restorers will use it to save money. Many restorers on this site will use Arauco-ply,, which is a little more expensive than cheap exterior grade ($30-35 a sheet), but is of higher quality, with more plys. Marine is the most expensive, and will run about $65+ from Menards.
