Re: canoe side motor mount throwing water in canoe
Like you, I mounted a motor to my 15.5 ft canoe as well. For my setup, I mounted its battery in front of the boat. I then ran large 12 Volt battery booster cables to the Minkota 36lbs motor - mounted at the rear side of the boat. Thus, making the canoe site more level on the water. And, I adjusted the height of the motor up and down to find its "most optimal" water depth as well.
For your setup, can you move the gas tank to front of canoe as well? Can you move your supplies to font of canoe as well? Also, does your gas motor need to be more or less deeper in the water as well?
BTW: A picture of how you connected the motor to your Canoe would help us as well...
