Re: Might you know of a brand of Ski pole/post that work well with I/O Wellcraft boat
I call BS on the deep-water start. The angle difference from a standard ski pylon to a ski tow ring on the transom is negligible at 60'+, so it will make little difference on getting you out of the hole. While having a center-mounted point does help fight the issue of tracking for the skier pulling hard, inboards do not have an outdrive in the water to combat the pull, either. Secondly, if the skier pulls hard enough and is that concerned about it, he wouldn't be skiing behind an I/O to begin with.
