This forum is awsome for knowledge.
My first boat project is pretty clean. It has been stored inside except for 10 months of it's life. I believe the guy because the boat still has the original cloth looking trim on each side and the fiber is in great shape but somewhat faded. I will post pictures later. I will add the model once I find the data plate.
The reason I chose a 62 is my restored 1962 Ford half ton 4x4 comes out of the paint shop this week and I thought it would look great pulling a 62 boat with matching paint.
It was priced at $500 firm, the seller just finished rebuilding the carb and could not get it to run smooth in transition between slow and fast speed. He said the engine compression is the same on all cyclinders but very low at 35 and he wished he had checked the compression before spending money on the carb.
My first question is should compression be checked cold or hot for comparison to the specs?
My second question is, will I be ruining the value of the boat by painting the exterior a deep sea blue? The original paint is beige. If I am ruining the value, is it in the hundred dollar range or thousand dollar range?
My third question is, how is the best way to go about trading my 62 75 hp for a 1962 40 or so hp? I am 60 plus and tilting a 75 without power tilt is going to be too much for me. I live in Northern Oklahoma where the wind is a factor so I am guessing 40 hp is the least a 16 footer should have.
Dennis
Dennis
