steering wheel has some play in it (cable system)
wpg manitoba
The steering wheel has about 1/10 -1/12 of a turn of play. I have always used tillers so this whole steering wheel system is new to me and not sure if this is normal or not. It uses the cable style
Help?
Re: steering wheel has some play in it (cable system)
Help?
Ayuh,... That don't sound Bad,... It's a boat, not yer car,....
MH Hawker
All of them have a bit of play.
You didn't say what type of boat, but yes, a bit of play is normal for a single cable system. If you have a real need to get rid of most of the slop (i.e. higher performance boat) you can get a rack system with dual cables.
snowman48047
I noticed this just the last couple years on my Lund. I thought the steering system was going. I traded in my old Merc for a new 115hp and they said there was a nut loose that caused it. Check everything and make sure its all tight.
wpg manitoba
Everything is tight. I haven't used steering wheels for boats ever so I guess I wasn't sure what is normal and what isn't. Guess I'm used to car steering wheels and any play on a car steering wheel would be cause for concern. It's a 1970 aroliner that I was restoring. The steering wheel and cable came with the boat, they look to be in decent shape.
I am surprised that a lot of older boats still use the pulley and rope system. I'm glad my boat didn't still have that system on it.
Woodonglass
I have a 1961 Lonestar with the Old Pulley and Rope steering and it works Great with No Play in it. I regularly check the pulleys and keep em greased and the pulley is new so I anticipate no issues.
