Re: Holding Tank Question
Better to pump it out if you have the opportunity. Aside from the obvious, solid waste tends to turn to bricks especially after mixing with the paper (you should be using biodegradable marine paper). Pump it out and add a few gallons of clean water along with the correct amount of deodorizer. Vent tank filters also keep odors at bay.
