KnotConnected
- Aug 15, 2012
- 221
I.
...am *seriously*
confused.
Original issue: Bennett trim tabs were working on my '94 Larson Cabrio 280. but when they were activated, either tab, either direction, voltage dropped down to 11vdc .
Troubleshooting: I have verified the *entire* length of the harness from the pump up to the helm switches is in good shape. Cut, re-crimped and shrink tube'd ALL terminals. NO changes..
Then, I removed the harness, and using a test-harness I made, wired the pump's Red & yellow wires directly to the battery positive to activate port valve, pump reverse (lifting the port tab), and it works fine, and voltage remains at 12v. so, the pump has to be fine, and the battery has the juice to power it.
THEN, I removed the ground from the pump, thinking maybe it's weak. Replaced with slightly heavier gauge, wired back directly to battery's ground terminal (where it was before). Tested, and now the pumps don't work at ALL, and voltage drops to ~8 volts. 'EF!
SO, what I know...
*there IS 12v on the dual-rocker helm switch's 12v terminal. at it should be.
*Testing each of the other terminals on the helm switches with a multimeter, none show any voltage UNLESS the switch is pressed (working as it should..)
* +12v power source going into the helm switch comes off the ignition key switch on the helm (where it should come from, says Bennett)
*The harness is good
*The battery is good
*The ground is good (testing from battery + to the terminal on the pump is a healthy 12v
*That same engine-battery 12v power source that goes to the ignition key switch (and up to the trim tab switches) seems to be working well, as the engine cranks no issues.
the ONLY other unexplainable anomaly is that when I turn the engine battery OFF, all that stuff stops working, as I'd expect it to. ...however when testing the positive terminal on the trim tab switch with a multimeter, it shows 1/3 volt. If i shut BOTH batteries off (the other is for aux systems, lights, radio, bilge pumps, blower, etc..) the voltage goes dead. so, SOMEHOW, very slight positive voltage is still making its way to the ignition switch (which shouldn't
have any power to it.)
I'm absolutely at a loss here, so if anyone has like, *any* suggestions, or input, or ideas, I'm all ears.
thanks! (and sorry for the novel. I wanted to try to include everything I've done / concluded)
...am *seriously*
confused.
SO, what I know...
