Ok I purchased this used today and the motor kicks on, but as I could see it was seeping fluid out of the shock inlet to one of the hydraulic lines. So I unscrewed it(both the line and the bigger nut the line goes into) after taking both the line and nut I noticed neither had any orings just umber tape, so I bought 2 o-rings and put in then screwed them both tight, fluid still leaks cause when I manually separate the tilt/trim with my hands and then push then close I can hear and see bubbles out of that line.
Also the unit does not open when I jump it to battery but I'm assuming cause there is little fluid in it.
This unit leaked most of the fluid out just by sitting flat in a box not mounted to a hulk or motor.
Please help!
Thanks
Please help!
Thanks
