Re: G Tech pro
Why? Almost all of the functions of it will be useless. So the first problem is that it calculates horsepower based on losses that a wheeled vehicle has. Hull drag is an entirely different matter. The other big problem is that it works by using an internal accelerometer. in a vehicle, its reasonably accurate because the vehicle stays more or less level during acceleration. In a boat, you could easily have 20 or more degrees of bow rise during acceleration, the g tech will see this as acceleration, even if you aren't accelerating at all! If you hold your boat at the speed where it plows water, the gtech is going to think its accelerating at a fairly good clip!
