I bought some inexpensive bilge cleaner. Poured it in and forgot it. Some time later all the oil and crud was floating and I too did the drain plug and wash out.
Simple Green, spray it around good, then spray with water, repeat if you have to. If you have real bad places, you can hose clamp a brush to a pole, and scrub it in.
