Hi guys, I need some help.
My insurance company sent me this "Required" Survey to fill out and there are some questions out of the 100,000 they are asking, that I have no clue on what they are talking about or if it even relates to my boat.
I'm hoping someone might be able to help me out with this. Listed below are the questions they are asking and my comments in parenthesis.
Thanks a lot
Fuel System:
1. Fuel deck fill properly grounded and labeled with fuel type (Should there be a ground strap or something attached to the neck?)
2. Fuel shut-off valve at tank - also engine if in separate compartment (No idea)
3. Do all fuels drain overboard in the event of an accidental overflow (Umm, where else would it go?)
4. If fuel filter has a bowl, is it made of metal (I think it's just a canister type)
5. Is the blower suction hose free of holes, unnecessary bends, and positioned to draw air from the lowest spot in the bilge, but above normal bilge waters? (Uhh what??)
Thru-Hulls and Hose:
1. Are all below waterline thru-hull fittings equipped with shut off valves? (Are these those round holes under my live wells?)
2. Are shut-off valves in good working order? (Dunno if I have any and if I do, how would I test it?)
3. Are all thru-hulls free of any restrictions such as barnacles, marine growth? (I'm sure that's not an issue, but Spiders... Spiders maybe. Again if these are the round ports/hole under the live wells, how would I check? The floor of the boat covers them)
4. Are all hoses connected with a double hose clamp? (All my hoses seem to run under the floor, how the heck would I know?)
5. Are cockpit drains and scuppers watertight to the hull? (???)
6. Is the engine's raw water strainer free of debris? (Is that the fuel/water separator?)
Electrical:
1. Is there only one splice in any length of wire? (They're joking right?!?)
Thanks a lot
Fuel System:
Electrical:
