Re: 55 Gallon poly drum lift
I have seen the floating lifts for sale. I have also seen the pricetags. $$$$$$$$ I don't recall the name of the manufacturer, but one company builds docks very similiar to what I envision using square, hollow poly tanks". I think they use air to evacuate the water instead of pumping.
One of the attractions to me of designing/building this lift is that I anticipate using it in a concrete slip. The design would be such that the boat would be completely out of the water, and the barrels would give spacing/cushion between the sides of the slip and the bow. Also, it wouldln't require much in the way of "permanent" installation at the slip. The marina I plan to rent the slip from only allows lifts to be installed by their employees, as they want to be certain there is no damage to their docks, so I am looking to minimize the install time. Of course, before building this lift I would make certain the Marina was ok with the design. If I build it, it would be towable so I could do all the assembly, tow it behind the boat, slide it into position in the slip, let the Marina tie it off/attach it to their dock. Of course, if I decide to build this, I would give it a trial run prior to taking it to the marina.
Still looking for someone that has actually built one like this. The comments and advice so far are appreciated, but I am really hoping to hear from someone has tried to build one and can give first hand experience on how well it worked/didn't work.
Thanks
