replacing hot water heater in a sea ray
mysearay38
I have a 2001 380 sea ray sundancer. I need to replace the hot water heater. The water heater is under the aft couch.
The couch is electric. I need to pull the couch or disassemble it to replace the heater. Does anyone know how to do this.
Grub54891
Re: replacing hot water heater in a sea ray
As with most boats,somthing has to be taken apart to get at what you need to do.Take pics as you dissasemble,and check em when it goes back together.
Grub
mysearay38
thanks for the in put . went down to boat last night and got old water heater out. Will put new one in tomorrow. If anyone needs to know how to do this job you can email me (please read the forum posting rules)
GA_Boater
Don't use email. Your next post should be the "How to" instructions.
A year from now or longer, you may not be in position to supply the how to.
