This might not be the best place to post this, but I can't find anything better.
I own an Alden 18' rowing shell. It weighs about 120 pounds. It is essentially a flat bottomed heavily built fiberglass canoe with an insert that makes it a rowing shell.
Rowing Shells and Accessories from Chesapeake Rowing - The Alden 18 Double Rowing Shell
I live on a Finger Lake in NY, but have no beach. My waterfront is stone/concrete wall at the water, about 4' above the high water line (with 8' of grass even with the top of the wall). If I have to lift the boat onto the wall each time, I won't be using it much.
I had the idea of building something like a hoist out of either pipe or wood, only with slings that would hold the boat about a foot and a half out of the water. During Sandy we had waves about 2', so 1.5' ought to be okay. Presumably this is not an original idea; if you have seen it before, I would appreciate knowing how it has been done.
The boat can't be turned over; the stuff that make it a rowing shell rather than a canoe is held in casually, and is not stable upside down. So, I was thinking of putting one or two drain plugs in. Does this make any sense?
Any advice on how to store this shell would be appreciated.
