I am finally getting the time to get my Skipjack together! I am replacing all of the exhaust components and I've already replaced the manifolds and risers. The previous owner set the boat up to have the exhaust exit under the swim step.
The way he did this was using "S" pipes from the risers that lower the exhaust point and put it under the water. He installed what I would call "scuppers" inside the old "S" pipe. Presumably this was a precaution to ensure that under deceleration water wouldn't be forced up the S pipe and potentially into the engine. There are flaps on the outside of the through-hulls for the same purpose.
In order to install these scuppers, I'd have to find them, then drill the S pipes and install them. Presumably the clamp will be right over it and the hose will cover the hole so it should be sealed. I've never seen a setup with both flappers and scuppers so I'm curious if you all think it's necessary to reinstall in this fashion?
Thanks in advance. I've attached pics of the new pipe and the old pipe.
