minuteman62-64
- Apr 12, 2011
- 1,350
I'm in the process of installing a new backing piece (laminated plywood) for my bow eye. It will fit into the "V" of my aluminum hull's stem. I've shaped it to a good fit and plan to slather it with 5200 when I assemble it so the 5200 will fill any gaps and also tie the whole thing together.
In the past, when I've used silicone compounds for similar applications, the drill was to firm up the fasteners till the silicone just began to ooze out, wait till the silicone set up and then tighten the fasteners.
Same drill with 5200? Final tightening after a week or so? Or other procedure?
