I just purchased an older Tracker boat (15') and it came with Swivl-Eze seat system. The issue is that the previous owner hacked (literally) the pedestals down to lower the overall height of the seats.
Fine for him, not so much for me. I was able to remove all the pedestals except the one for the driver position (thanks to iboats forums) by wiggling until free. The driver's post is NOT going to come out, which brings me to my question. Are the seat bases screwed into the (raised) floor, or through-bolted. I have wiggled the post so much, at this point, the base is actually starting to (slightly) loosen from the floor.
If I can unscrew the base, I can either pound out the post and reinstall the old base or buy a new one and install.. If the base is bolted down, then I will have to remove the floor, another project in itself.
Thanks.
Thanks.
