Hi, just got a boat it's a 1987 procraft fish and ski 19 ft with a 150hp Mariner. This is my first boat of this style. I have a couple questions that I hope someone can answer, they should be fairly basic.
1st, the boat needs a new battery. There are several different types of batteries available, what should I get? Is the bigger the better?
2nd: When I get the battery, where do I sit it? On the aft of the boat there is a large door and under that door is the gas tank, a oil tank and the rest of the bilge and wires, but I don't see a plate or anything to rest the battery on. Do I just sit it wherever it fits?
3rd: When towing the boat what is the best position of this large motor? (I've read mixed reviews for smaller motors, some say down to relieve stress to the transom, some say 45 deg angle and some say all the way up) The engine is mounted to a turbo tilt transom bracket if that means anything.
4th: On the engine there is a manual lock which keeps the engine in the up position, I've read on other boats to only use that when you need the engine up for a length of time and not to use it when towing.
Thanks guys.
Jeff
Thanks guys.
Jeff
