Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
See more
See less
short shaft ON long transom?
This topic is closed.
  • short shaft ON long transom?
    I have a boat that is a long transom (19").... And I have a short shaft 40hp 1995 Johnson TILLER steer outboard. So....My question is; Can I use this outboard on my boat IF I use a jack plate? For example, will a fixed jack plate allow me to mount this low enough on transom to have cavitation plate where it needs to be AND still be able to use tiller handle and a engine controls? Or will lowering outboard a couple inches cause the tiller handle to hit the transom and not be able to turn / tilt.
    (the plate I'm thinking about will set outboard back 4"). oh, and boat is a Tracker Grizzly 1648
    Please advise.
    Re: short shaft ON long transom?
    Jack plates work much better for a long shaft motor on a short shaft boat.
    I'd say your steering will be close if not impeded.
    I consider overkill a job well done... plus a little extra.
    There's as many ways to do something as there is people to tell you how to do it... but not all of them are the right way.
    The drinking and debauchery will continue until morale improves... and maybe for a little while after.
    • #3
      Please do not post multiples, 95Johnson. Your thread in the Johnson/Evinrude forum has replies.
      Please review and respect our rules.
      Thanks for your cooperation.
      sigpic
