cuenta
- Apr 26, 2011
- 137
if ever happens that the battery dies
We can use this method
1.Remove the cowling.
2.Tie a knot in the end of a 6 mm (1/4") rope and wedge the knot into the notch on top of the flywheel.
3.Wrap the rope around the flywheel in the correct direction clockwise.
4.Set the choke and throttle.
5.Pull really hard.
6.Repeat until it starts. (Do not attempt to put the cowling back on while it's spinning)
video:
How to pull start a flat electric start Outboard - YouTube
carefully this method can cause injury
if anyone has other options give suggestions
5.Pull really hard.
video:
