Re: BRP Control LHS to RHS conversion
The control unit, (for throttle & gear selection), is configured with the lever on its right side for port side mounting,, I need to get the lever to the left side for starboard side mounting. The control is easy to pull apart but the trim/tilt wire from the lever enters the control housing through a small hole & I cant see how to extract it because of the connector plug is larger than the hole & the other end is at the trim toggle switch & I don't want to attempt to disconnect the wires there & risk damaging the switch,, same applies to then re-connecting it through the same size hole on the other side of the control body,,
Hope this makes some sense,,
Ta NevW
