Mike Drelich
- Jun 29, 2012
- 2
Replaced my side panel and side mount controller after reupolstering my 2000 190 Four Winns 4.3GL. I am now unable to idle down below 1500 RPM's. If I reach behind the side panel and grab the throttle cable at the point of attachment on the remote, then slightly pull aft, the idle will drop back down to it's normal operating range. However, once I increase speed and throttle down the idle returns to 1500 RPM.
Before I remove the panel once again I want to be absolutely certain that the problem is correctable at the side mounted control. Appreciate any help you can give to this new guy. Mike
