Bustedknuckle84
- Sep 29, 2010
- 421
I have the bennett sport tab i believe its the m80 model with the trim tab indicator with seperate controls for the trim tabs. The starboard side works fine the port side is stuck open. Heres what i have done so far.
Cleaned all connections at helm and gound wire from the hpu to the battery.
Verified over 12.3v going to the selonoid and motor(red and yellow wires) inside the hpu.
Swapped the hydraulic lines made no difference which verifys the motor and valves work fine because the starboard side still worked fine.
So i narrowed it to the actuator. I took it apart which dropped the pressure so it collasped again.
Now the issue is once i hooked it up again and run the tab all the way down i heard a pop and it wouldnt come up again. If i move the tab down but not all the way down it would come back up.
