I have a 1994, 17' Cajun bass boat. My problem is that the front live well does not fill. I have access to the front outer side of the well to see that the hose that supplies the well is gone. I can see the pump from the rear two access hole in the transum and the control valve. The valve has at least one hose missing and has no control cables. I am assuming that since it looks like two hoses are laying ahead of the valve that their was a problem with the system and someone has disconnected the hoses at a minimum. I have removed the fuel tank and seats to get down to the hoses and valve. No luck as all that's ther is a small 6" hole like on the transum. the front hole and two rear holes are about four feet apart and not big enough to even see. How do you work on this system without cutting the boat apart?
