rfdfirecaptain
- Aug 17, 2008
- 314
I have an appreciation for the funnies and "punnies" that I expect to follow this post... however, I really need some "solid" adivce on this one.
While swapping my engine we banged my aluminum waste tank about 5 inches from the bottom of the tank. It left a 1.5inch long by 3/16 inch wide gash. To get by, I used a whole tube of Loc-tite epoxy putty... squeezing the putty onto the hole and flattening an edge about 1 inch wide, 1/4 thick all around. That repair has worked pretty well. I've had to replace the putty once in two years after it worked itself loose from the hole.
I am wondering if there is a more reliable repair that is specifically designed for aluminum. Something that does not require welding, will work on a vertical surface and will withstand contact with waste and waste treatment chemicals. Any ideas?
Thanks! Now let the jokes begin.
