bleedblue94
- Oct 11, 2010
- 272
hi, i recently did a restore on an older boat that used a dedicated fuel fill and a separate vent for the tank. while doing the rebuild i switched to an attwood combination fill and vent to prevent spills when fueling. i noticed the cap for this seals the vent and the tank fill at all times except for when the cap is open, ie when i am fueling (it does NOT allow the vent to be open at all times). im wondering if this is causing excess pressure on my plastic tank? when i open the cap i get the sound of pressure equalizing. should i switch back to a dedicated vent that remains open at all times? should i T off the line and install an open vent at a higher position than the fill so it vents the tank at all times, but also have the line go to the combination fill/vent so any "burps" while fueling will most likely go the path of least resistance (aka to the lower vent which would be located in the fill) and recycle back down the fill?
thanks
thanks
