Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
outboard engine steering problem/ frozen
  • outboard engine steering problem/ frozen
    hi and how are you? i have 95 bayliner boat with a 120 force outboard engine. i bought it two years ago. the day that i bought it the owner told me he has just replaced the steering wheel cable. 8/16/2012 i tried to get my boat ready for the lake, and i noticed that my engine is not moving at all. the steering will hard and i tried to move the engine with my hands and i can't move the engine at all.
    what might be going on and what is the fix.
    Re: outboard engine steering problem/ frozen
    I just went through this with same set-up...'95 Trophy, Force 120. In my case I had to change out the tilt tube, so hopefully you'll be a tad luckier, although it wasn't "that" tough to do.
    Start by disconnecting your cable on the Port (left side facing from behind) side of the motor at the steering arm. SHould be a threaded nut to remove, then pull up the arm to disconnect and verify the outboard will turn freely without the cable attached.
    If it does, then you've got to replace the cable. Report back your findings and we'll go from there. If it doesn't, check your cable by turning the steering wheel while it's disconnected.
    "If it ain't broke....don't worry, 5 minutes with me and it will be!"
    1996 Trophy 1802 - 120hp Force (by Mercury...snicker)
    8' Hardbottom Dinghy w/Evinrude 6hp OB (oh yeah, this is the 'boat')
    In the market for nice, local area, sailboat, with the operative word being-"cheap"
    • #3
      If the cable works without the motor, then it's an "old grease issue" in your Kingpin (main motor swivel point). SHould be 2 grease fittings, top & bottom. If it's not "too" bad, you can push the old grease out with the new grease via a gun.
      If, however the cable still is stuck, then the simplest fix is to lift the motor and push the tilt tube out and apply heat in hopes it frees the cable. Mine is STILL stuck so I had no choice but to cut the cable and replace the tilt tube. Try and find a used one if so, because new they're $200, PLUS the cable ($120ish).
      Attach a line to the stern end of the old cable with strong tape and pull it out from the console area. The line is to fish the new back through. It should come out easy if it's been replaced once...*mine hadn't been....ugh.
      Feed the new cable from the console back and connect back to the pivot arm and then go boating!
      • #4
        Feeding the cable, old or new is a 2 man job (or 1 man and 1 woman in my case). It looks daunting but it's really not. And, I forgot to add above, reattach the motor before you go fishing, btw....lol. Keep grease on the cable at the motor from here on. Obviously the PO did NOT! Simple to do and saves $$ and aggravation.
        • #5
          http://forums.iboats.com/showthread....22#post3927022
          If the steering is frozen, disconnect the arm from the ram that passes through the tilt tube. It should be a small nylock nut and bolt on the port side of the engine. Then see if the engine turns. If so, your cable ram is frozen in the tilt tube (most likely). Loosen the large nut on the starboard side of the engine that holds the cable. Spray both ends with PB blaster and then try tapping the exposed ram with a wooden block and hammer - make sure you don't mushroom the end of the ram. You might need to apply some heat - do a search for frozen steering. Good luck!
          • #6
            Only loosen the "Chrome nut" on the STB side, too. Those other 2 on each side of the tilt tube (where the cable feeds through at the motor bracket) are holding your motor on.
            • #7
              ok i will try to do as you say asap. just thought i should post some pics
              engine is right at the middle
              • #8
                Clearance like mine which is why I had to pull the motor (if the tilt tube is the problem). I would definitely start looking at ways to pull that motor. BTW, that nut on the left is the one to disconnect the motor from the cable to check where the issue lies. You'll get it.
                • #9
                  Not a lot of working room on the port side, disconnect the linkage by removing the bolt. It will then allow you to pivot the motor side to side and give you a little extra room. Work on loosening the dull metal nut on the starboard side at the end of the cable. Once you get both free, spray both areas with PB Blaster. You can try putting a wrench on the flat at the port side of the ram and see if you can twist it to help free it up. If all else fails, I would work on removing the engine so that you have a clear shot at the end of the ram. Place a 2x4 over the ram and give it a good shot with a large hammer.
                  By the way, you have a 15' cable. The part number ssc13415 is the teleflex part number, the last two numbers being the length.
                  • #10
                    I took mine to a shop years ago and had them torch the housing around the kingpin. It loosened up all the old, corroded grease, Pumped in a buuuunch of new grease and problem solved. There are many on here who have done same.
                    • #11
                      i dont have a torch but i have a heat gun. i will apply all methods the day i will work on it and i will update ya. thkx
                      • #12
                        In the second picture it shows the connection between the cable and the Link rod. Pull the nut off the link rod and see it the engine will turn. Then turn the steering wheel and see if the cable moves. Should tell where the problem lies.
                        1984 Lund S14 DLX, 35hp Evinrude on a Spartan Roller Tilt trailer. Sold to little brother.
                        1988 Alumacraft Classic 16 under reconstruction.
                        1984 Sea Nymph FM144 Pike Attacker, 1994 Johnson 30hp
                        195? Rich Line 14', the stump bumber
                        • #13
                          Hi? here is what i have found from what ya advised me to do. i removed the bolt/screw/nut that connect the boat to the steering rod and the engine moves left to right and right to left just fine. i tried to turn steering wheel but it doesn't turn.
                          then i removed the nut on the right of the engine where the steering cable enter the boat and connect to the rod. with that the bolt loose the steering wheel turns right and left. then i screwed back the nut that i remove and the steering stock again. pls take a look at the pics.
                          what next should i do? i thought about spraying like a grease degreaser inside to unclog the grease
                          with the detachment of the engine control rod the boat moves
                          with the nut is loose the steering wheel move but when i tight the nut it stop moving
                          • #14
                            What will happen if i lose those two black nuts?
                            • #15
                              What do you mean, "the boat moves."
                              When you are able to get the steering wheel to move, does the cable move inside the tilt tube? I'm guessing not. It seems the cable is frozen in there.
                              Bob, Seneca Lake NY
                              '88 Bayliner 1700 Capri bowrider, 85 HP Force O/B, "Sea Weasel"
                              '94 Grumman Fish'N Fun pontoon, 40 HP Merc
                              Want a vessel safety check? Click here. Want to join the Coast Guard Auxiliary? Click here.
                              Disclaimer: Although I am a member of the USCG Auxiliary, the opinions and advice in my replies are my own and do not necessarily reflect CG or CG Auxiliary policy or regulations unless so specified.
