Re: Stingray or Stingray Junior for 40hp evinrude?
Thanks but that wasn't the question I asked, I had a doel fin and didn't like it, sprayed a bit and flexed.
Sorry if I evaded the original question. I assumed you had a problem and wanted to correct it. My answer was directed toward the root cause of the problem.
The larger model is the one you should buy. The Junior will be too small for your application.
Nevertheless, I'll fall into the same hole again - hope you don't get mad. If the DoelFin flexed and sprayed, I'm quite confident that the Stingray will be worse in that regard. The bigger one will flex more than the smaller one.
Trailer Boats Magazine did a "shootout" of all of the hydrofoil brands a few years ago. That was an enlightening article, plus I speak from personal experience.
Flexing and spray are due to either an improper installation, or the motor is not at the proper height on the transom.
Make sure you buy the drill and bolt on model. If you buy the clamp on model you'll have even worse luck with it.
